I use 3point UCS to set unnamed UCS with custom line. I need change start Z=0 and End Z=0 to other line staying in this unnamed UCS.
I want to assign keyboard shortcuts to this operation.
Thanks for any help in resolving this issue.
yes I tried it. But this command move Z=0 in the world UCS
but I need it relative to 3point custom UCS
Ae you talking about flatten?
Because the move-macro shouldn't do that.
Try this makro or do manually, move all from 0,0,0 to 0,0,1e99
and back again from 0,0,1e99 to 0,0,0
Sebastian
you mean this macro: ^C^C_UCS;;_select;\_move;_p;;0,0,1e99;;_move;_p;;0,0,-1e99;;
but it works only in world UCS
I set 3point UCS at custom line and need set other line Z=0 relative to this custom unnamed UCS
FLATTEN command not an option? This forum is for AutoCAD, not LT, may I ask why you are trying to use an LT macro? Or does your post need to move the LT forum.
OR (for AutoCAD, not LT)...
what is the difference between AutoCAD and AutoCAD LT macros ?
flatten doesn't work with unnamed UCS built by the 3point UCS
@raffanLRBFP wrote:what is the difference between AutoCAD and AutoCAD LT macros ?
AutoCAD has full access to programming languages that allow for detailed customizations, LT is very limited. And that macro you are testing simply repeats what you can type at the commandline, hardly any intelligence at all.
With LISP or the other programming languages let you work with the program's limitations instead of fighting them: perhaps you can give your rotate UCS a temp name then do what you need on the fly. There might be one or more LISP already out there, look for them and give them a try.
@raffanLRBFP wrote:
you mean this macro: ^C^C_UCS;;_.....
No, this macro is not posted in the linked thread, and it isn't want I explained to do it manually, Paul quoted the macro for you above.
The steps are without this red part (UCSenterenter switchs your ucs to wcs, that's why it isn't working for you).
Sebastian
As I work, I create a custom UCS dozens of times in one drawing. If I give temporary names for each UCS, then there will be no point in creating a macro to speed up the process.
@raffanLRBFP wrote:As I work, I create a custom UCS dozens of times in one drawing. If I give temporary names for each UCS, then there will be no point in creating a macro to speed up the process.
Umm, so you don't want the LISP to do all the heavy lifting then @raffanLRBFP?
