set same text color to multileaders
salelukov
Message 1 of 22
salelukov
is there an option to set the same color for texts in all multileaders?
i solve the problem with fonts, but now I am bothering with the colors...
Replies (21)
Message 21 of 22
TheCADnoob
I'm not sure where we are with this one, i had to step away before posting and the subsequent thread is hard to follow. If the problem is solved please disregard. Im going to post my work around just just incase in the future some on has LT and cant use stripmtext.
This wont do them all at once, but it can be done per multileader. if you change your MTEXTED system variable to be notepad (you'll have to find that executable on you system and past that into the MTEXTED prompt. Mine is : C:\Windows\System32\notepad.exe) you can get ahold of the overrides.
Once your mtext editor is notepad you can wipe out the format overrides.  Select the overides then hit save and close notepad.
Once all thats gone you can change the multi leaders with the properties pallet.
After you are finished remember to change your MTEXTED back to internal.
CADnoob
Message 22 of 22
pendean
Community Legend
Community Legend
@salelukov it appears manual edits are required for each item. Sorry.
