When separating solid bodies (Solidedit > Body > Separate) with the solid on one layer & my current layer is different - how do I know which body stays on the solids layer & which change to the current layer?
It seems to be rather random - sometimes the selected portion stays on the solid layer & sometimes the selected portion changes to the current layer
Am I missing soemthing obvious?
The attached drawing (this was done with AS but the same thing applies with all AutoCAD flavours).
1 - 2 solids intersecting eachother - 1 on trash layer & other on standard layer. Trash layer is current
2 - Subtract trash solid from standard solid leaving standard solid in 2 parts but still 1 piece (not sure that came out properly)
3 - copy 2 to 3 & Solid Editing > Separate > select top part = top piece stays on standard layer & bottom piece moves to current layer (trash)
4 copy 2 to 4 & Solid Editing > Separate > select bottom part = top piece stays on standard layer & bottom piece moves to current layer (trash)
So is there any way to predetermine which part(s) move to current layer & which part(s) stay on its layer?
