Selezione linee
Selezione linee
cellerino
Message 1 of 11
Selezione linee
cellerino
Buongiorno,
da qualche giorno ho un problema con Autocad 2019,
capita, ma non sempre che copiando, ruotando, specchiando una o più linee (cerchi, blocchi ecc.) li visualizza ma non mi permette più di selezionarlo fino a quando non chiudo il file, riaprendolo torna tutto apposto.
Mi potete aiutare?
Grazie
Replies (10)
Message 2 of 11
Alfred.NESWADBA
which version of AutoCAD? (please start command _ABOUT and send us a screenshot).
Does the same happen, if:
  • you disable hardware acceleration (command _GRAPHICSCONFIG)
  • if you change the layout and back to modelspace
  • try the same in a new drawing
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 3 of 11
TheCADnoob
What layer are you working in?
Are you editing an xref?
CADnoob
Message 4 of 11
cellerino
I working in Bylayer
No
Thank you
Message 5 of 11
cellerino
The version is :P.46.0.0 Autocad 2019
I'll tray
Thank you
Message 6 of 11
cellerino
Sorry, layer 0
Message 7 of 11
Alfred.NESWADBA
Just one answer for 3 suggestions/questions 😉
What about trying this in a new drawing, alternatively with disabled hardware acceleration?
Anyway, P.46 means you have not installed any updates for your AutoCAD, it should show like:
- alfred -
Alfred NESWADBA
Message 8 of 11
cellerino
Hi Alfred,
I've tried on new design, same problem with disabled hardware acceleration.
Message 9 of 11
Alfred.NESWADBA
then please install the update 1.2 (2019.1.2)
- alfred -
Alfred NESWADBA
Message 10 of 11
cellerino
HI,
I updated
now I wait
thank you
Message 11 of 11
cellerino
Thank you.
It's ok
