SELECTION SETS AND PROPERTIES PALETTE
I have several users who seem to be unable to pass a selection set to the properties palette.
For example, I want to create a selection set of all viewports on a page. I can say:
Select
"filter
(create viewport filter, add to list, apply..all)
Then I can either hit return (enter) one more time and it will pass that selection set to the properties palette, or I can reissue the select command and select the previous selection set, which also passes the selection set to the properties palette, and from there I can lock all viewports by selecting the display locked property for the selection set.
I want the properties palette to look like this:
This is not happening only for viewports, but all selection sets.
Is there a system variable that affects this? I have tried pickfirst, but that doesn't work.
Any help appreciated.
Kent1Cooper
After your Select command, try this:
(sssetfirst nil (ssget "_P"))
If that doesn't do it, what happens?  Are there any messages?  Etc.
Kent Cooper, AIA
I usually do it (setq a (ssget "P")) to create a named selection set I can use later. (select !a)
No that doesn't work.
However, I did find the solution -
set "pickadd" to 2 instead of pickfirst.
