Selection Preview Issues
Andrew.Pilon
Andrew.Pilon
I'm sure this is just an easy setting somewhere but I can't figure it out. I have a Tech that suddenly had any selections she had start appearing like the first picture below with all the nodes highlighted. Before it would just select everything like the second picture. It doesn't affect how she works but I'm very curious as to which variable or whatever changed. Anyone have any ideas?
Valentin_CAD
@Andrew.Pilon ,
Please provide us the AutoCAD version you're using.
Also, post a drawing containing the two dynamic blocks for all to troubleshoot.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
jayhar
Set Selection Preview:
SELECTIONPREVIEW
Try changing the value to see which setting provides the desired behavior:
  • 0: No selection preview
  • 1: Highlight objects, similar to your second picture
  • 2: Highlight objects and display grips and edges, similar to your first picture
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
Kent1Cooper
Un-check this:
Kent Cooper, AIA
Andrew.Pilon
@Valentin_CAD  I can't upload due to security issues. IT just won't let me.
@jayhar  I had tried that one. It's not it.
@Kent1Cooper They aren't actually grips, just dots. They look more like spline dots.
Seems to have fixed itself on her computer after the morning though so I don't know what's going on.
pendean
Community Legend
Community Legend
@Andrew.Pilon wrote:
... Seems to have fixed itself on her computer after the morning though so I don't know what's going on.
PC restarts are always a good first step to remove odd behavior in any software: that was probably it.
vinodkl
Hello @Andrew.Pilon
This is a bug in AutoCAD 2023 and 2024 which is fixed in the recent update 2023.1.4 and 2024.1. Please update AutoCAD to fix this issue.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
