AutoCAD Forum
Selection box not appearing
3 REPLIES 3
1833 Views, 3 Replies
Good morning,
Recently I have been getting the following issue more and more often. I have been using AutoCAD 2018 for MacBook for a long time but over the past few weeks it happens that I cannot see the selection box.
AutoCAD works perfectly and I am completely able to work on it normally, almost. When having to select something, the cursor works and the selected objects do get highlighted but I cannot see the limits of the selection box and it is actually quite irritating.
It is worth mentioning that this happens exclusively at the moment the software is started -- never after a while.
When this happens, I need to restart the computer. It usually starts working okay after that but it is already lost time.
Would you happen to know what could this be?
Is it a glitch of the software?
Screenshot - as you can see, the selected objects are highlighted but the limits of the selection box are not visible.Screenshot - as you can see, the selected objects are highlighted but the limits of the selection box are not visible.
3 REPLIES 3
imadHabash
i wonder what really you mean by selection box , we're here in AutoCAD ( plain ) forum ? you may need to ask here in this forum . AutoCAD for Mac Forum
All the best ...
Imad Habash
ennujozlagam
you can try this go to options > selection > tick implied windowing and allow press and drag for lasso and see if helps. thanks
vinodkl
Check if you have "3DCONFIG" enabled.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
AutoCAD Inside the Factory
