selecting objects from commands and through scripts
hardikyp
hardikyp
I am trying to write a script which generates a set of spline curves in 3D space passing through a set of points. Once these splines are generated, I want to select two curves at a time and create a lofted surface between these two curves.
I can select these curves with the help of mouse. However, I want to automate the whole process and do it using scripts. Can anyone help me understand how to select a particular object in my autocad drawing simply through commands and without the use of mouse at all?
Thanks in advance!
Kent1Cooper
I imagine it would involve saving each Spline as a variable after it is drawn:
  {whatever draws a Spline}
  (setq spline1 (entlast))
  {whatever draws the next Spline}
  (setq spline2 (entlast))
Then you would have a distinct variable name for each Spline, which you could use in LOFT commands.
If you always need to Loft between adjacent Splines in the sequence of generating them, you could have one such variable:
  (command "_.loft"  ... use the spline1 variable and (entlast) ...)
and repeat.
Kent Cooper, AIA
hardikyp
Thank you very much! That solved my problem
