Selected Object Blurry Appearance
Message 1 of 16
I've been using AutoCAD 2013 at work since it came out. When I upgraded to AutoCAD 2015, and now 2020, I observed that when entities are selected the highlighting changed from the dotted line approach to something like a neon tube. I am starting to have some issues with my eyes and this visualization method is kind of hard to look at as it makes selected entities look fat and blurry. I would like to know if there is a way to change this back to the method used in earlier versions.
Replies (15)
Message 2 of 16
ian.mag
Hey @Anonymous
Try setting the PRESELECTIONEFFECT system variable to 0
Message 3 of 16
Alfred.NESWADBA
if it's the color you want to change the system variable SELECTIONEFFECTCOLOR controls that.
You can also turn off SELECTIONEFFECT ... does that help better?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 4 of 16
I just tried that and it didn't seem to have any effect. Do I have to close and restart the program perhaps?
Message 5 of 16
Alfred.NESWADBA
That should look very different, but it depends on hardware acceleration. by any chance, is your hardware acceleration disabled or does your graphic card run on DirectX9 instead of DirectX11 (to be controlled using command _GRAPHICSCONFIG).
- alfred -
Alfred NESWADBA
Message 6 of 16
I have never adjusted hardware acceleration or changed/updated directX. I am just looking for info on those actions and so far ACAD help is not helping. Will try looking on line.
Message 7 of 16
OK, just checked hardware using the 3dconfig command and found it to be on but that I am using directX9. I will look for this on line as well.
Message 8 of 16
Alfred.NESWADBA
That means either your graphic card is not compatible with DirectX11 (from AutoCAD's point of view) or you have used a workaround (for previous versions of AutoCAD) so AutoCAD just uses the older DirectX interface, maybe because you had troubles with the graphic card previously.
When you start command _GRAPHICSCONFIG ... can you show a screenshot from that dialog?
- alfred -
Alfred NESWADBA
Message 9 of 16
I am using a computer setup as a "CAD workstation" back in 2012. It is running win 7 and there have been no hardware or significant software upgrades since. I believe they are planning on upgrading to win 10 in the near future but don't know if that will affect this issue. My video card is an AMD Radeon HD 6670.
Message 10 of 16
Kent1Cooper
@Anonymous wrote:
I just tried that and it didn't seem to have any effect. ....
Since that's in response to @ian.mag who suggested changing only the PRESELECTIONEFFECT setting, make sure you also change the [plain-old] SELECTIONEFFECT setting, as @Alfred.NESWADBA added.
Kent Cooper, AIA
Message 11 of 16
Alfred.NESWADBA
Yes, it will affect the whole situation as all drivers are then new (I hope Windows 10 will be installed from scratch and not as update from your existing Windows 7).
I also hope that Windows 10 is not installed on a workstation that is 7 years old. Some of your hardware will not be supported from Windows 10 (or only with some very generic drivers, that have then not a good performance).
- alfred -
Alfred NESWADBA
Message 12 of 16
Thank the gods, as simple a fix as one could hope for. and as nonintuitive as most things AutoCAD.
Message 13 of 16
This was not a solution to my issue and I do not know how it was listed as one.
Message 14 of 16
Alfred.NESWADBA
What exactly was the solution for you?
- alfred -
Alfred NESWADBA
Message 15 of 16
My apologies Alfred, it does look like you first posted the solution. I saw the selectioneffectcolor reference and missed your reference to selectioneffect. I noticed it when Kent mentioned it in post #10 and tried it which solved my problem. Also I hadn't personally indicated your posted reply #3 as a solution and was initially put off by it having showed up as one. I hope this clarifies things and I did like your reply. No hard feelings I hope.
Message 16 of 16
Alfred.NESWADBA
>> My apologies Alfred
Nothing to apology. 😉
That is what I saw ... SELECTIONEFFECT was the solution, so it was correct that (for future readers) post 3 is a valid solution?
Please un-select post 15 as solution as it isn't one (and people searching for solutions won't understand post 15 as one.
- alfred -
Alfred NESWADBA
