Selected items are showing as dashed instead of highlighted
Message 1 of 31
When selecting a line or object, it used to show as highlighted. Now when I select something it showing as dashed. I have tried the selectioneffect and preselectioneffect commands and have had no change. Is there a command prompt to change these back to only being highlighted?
Thank you
Replies (30)
Message 2 of 31
pendean
Community Legend
Community Legend
What exact version and variant of AutoCAD are you using?
What is your WIndows version?
Message 3 of 31
cadffm
Is your GRAPHICSCONFIG ON?
Sebastian
Message 4 of 31
AutoCAD 2015 LT
Windows 7 Professional; SP1
Thank you
Message 5 of 31
The GRAPHICCONFIG got turned off and it was put into Safemode. Not sure how that happened, but after a computer restart that fixed the issue. I had previously shut down AutoCAD and restarted and the problem persisted.
Thank you for your help.
Message 6 of 31
Kent1Cooper
The "dashed" effect is highlighting -- just a different form [the way it always was up until a few versions ago].  I assume you mean the "neon glow" highlighting.
SELECTIONEFFECT only shows that "glow" when set to 1 and  [from Help:] "When hardware acceleration is on."
Kent Cooper, AIA
Message 7 of 31
Hye,
      I m using window 10..Autocad 2017 version
problem 1# my selected lines shows in dashes not at blue or any other colour.
problem 2# when I change the text height visibility from dimension style open I can't see at drawing interface.
plz, help me to sort out this problem asap.
Thnx,
Syeda Nida
Message 8 of 31
Kent1Cooper
#1  See Message 6.
#2  What is "text height visibility"?  And what is "dimension style open" as a setting for it?  Some different terminology [i.e. standard AutoCAD wording] would be helpful, or you may be able to illustrate the problem with an image or a sample drawing.
Kent Cooper, AIA
Message 9 of 31
miliodass6
the same problem with lines
also it shows a square with a circle above as a spline!!
please help me solve this problem , i cant restart my computer because i ll lose my work
Message 10 of 31
pendean
Community Legend
Community Legend
Did you even read the responses already posted? Try Message #6 above.
And why would you lose your work, do you never SAVE your files? or SAVEAS? Or QSAVE?
Message 11 of 31
miliodass6
Message 12 of 31
miliodass6
i set 1 but nothing is changing.also the form in the picture above is mentionned as a spline sometimes
Message 13 of 31
If it didn't change even after you set SELECTIONEFFECT to 1, you can use command GRAPHICSCONFIG and enable the "Hardware Acceleration" on.
It works for me after I enabled it, hope this info helps
Message 14 of 31
jeppe3PNBZ
Thanks guys!
Message 15 of 31
padredimitry
This worked for me! Thank you very much!
Message 16 of 31
ah17835
Observer
Observer
Enter the OPTIONS command or choose it from the Application menu to open the Options dialog box. On the System tab, click the Graphics Performance button. Then click the Hardware Acceleration button to turn it on.
Your issue will be solved.
Message 17 of 31
billLKHKG
While turning hardware acceleration on does allow me to set SELECTIONEFFECT to 1 and get selected items to glow instead of dotted line, I now have lines all over the place. It looks like I'm trying to solve a very complicated murder mystery. Lines can't be selected or moved. Is there way to have hardware acceleration off and still get the SELECTIONEFFECT option to work as I would like?
Message 18 of 31
Kent1Cooper
@billLKHKG wrote:
.... Is there way to have hardware acceleration off and still get the SELECTIONEFFECT option to work as I would like?
Help even for 2023 still says the neon-glow effect is available only with hardware acceleration turned on.  Maybe a different graphics card / driver would do it....
Kent Cooper, AIA
Message 19 of 31
esulthan
Community Visitor
Community Visitor
Thanks a lot.
Message 20 of 31
rvkrubin
Community Visitor
Community Visitor
hey i have tried to do what it says in message 6 but it still wont change i am not sure how it even changed in the first place...but i changed the selection effect to 1 and it still wont change the highlighting ...
does anyone know how to fix this?
