select previous issues
I'm having a problem in Autocad 2018 when i use the select previous command and then click enter - the automatic action i get is move and cant' change it to other actions. it's extremely annoying as i use this shortcut a lot.
So i hit S then P then enter and it automatically shows me the 'specify base point' command which then automatically moves the objects.
Does anyone know how to change this so i can choose other actions like rotate, copy etc?????? I used to be able to but can't seem to find a solution!!
any advise would be greatly appreciated.
Thanks heaps.
jayhar
1, Enter new value for SHORTCUTMENU <1>
2, Enter new value for PICKFIRST <1>
3, Enter new value for PICKADD <2>
Select command will be used to create a selection set and then the selection set will be recalled by using the “Previous” option.
But first, Here’s how to use SELECT:
1. SELECT <enter>
2. Select objects <enter> when finished selecting objects
3. <enter> onve more to accept the selection set.
Note: You will see a total of the selected objects listed in the command line when the select command is finished.
PREVIOUS option
When asked to make a selection set in a command, if you have already made a selection set  of objects, you can use those objects by entering P <enter>. This will call the Previously selected objects.
Here’s how:
1. Start a command that requires you to “select objects:”
2. When prompted to “Select objects:”
3. P <enter>
4. <enter> again to accept the selection set for the command to use.
or
Autocad 2018  Reset to defaults settings
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
ian.mag
Hey,
Just did the steps that you've outlined above. Indeed it does move the previous objects!!
That should be because the command alias S executes the stretch command, and that's why you're prompted to specify a basepoint.
Try typing the entire word SELECT and then P. Alternatively, you can customize S to execute the the select command, by using the ALIASEDIT, from which you can enter any letter you desire.
Hope this helps you out.
Kent1Cooper
My suggestion:  Don't bother with SELECT first [instead of Stretch -- or have you re-defined S as the alias for SELECT instead?], but instead just type in the alias for the actual command  you want to use, and then use P for selection within that  rather than beforehand.
Kent Cooper, AIA
yess that was the issue!!
Thanks heaps for your help! Smiley Very Happy
As always simple and easy solutions. Thank you
