Select objects in Multiple layouts
Kellser
Kellser
Does anybody know of a way to select objects in multiple Tab layouts.
I have attached Hyperlinks to certain Blocks and inserted them in my Dwgs in paperspace and on different Tab layouts. Now I need to change these links.
Qselect only allows me to select the Hyperlinks in the Tab layout that is active. But what I want to do is Select all the Hyperlinks in all layouts so that I can use CHprops to attach the new Hyperlink.
I use the Hyperlinks to attach valve and equipment blocks to Spec Sheets.
Cheers
Kells
Kellser
I believe I solved my particular problem with the Find and replace text command. Simple solution for me. can I give myself an Att a boy!! Smiley Very Happy
But I would still be interested in a solution as to how select objects that are located on different layouts
