NOTE: "PICKFIRST" variable does not correct this issue.
When I select an object, then issue a command, CAD is then asking me to perform the action again. For example, I select a line, right click and pick the "select similar" command. CAD will then select all line on the same layer as the one I selected. Then, while all these items are selected, I again right click and choose "display order" and "send to back". At this point, CAD asks me to select which objects. In the past, up until today, it would have moved all the selected lines to the back. Another example, I select an alignment, then right click, then choose "Offset Alignment" in the ribbon. It then asks me to select the alignment (even though I had it selected to issue the command). I have already tried the "pickfirst" setting and that did not solve the problem. Any help is much appreciated!
