Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
Is there a way to select an entity and displaying the selection on the view?
The end result should be the same as selecting an entity using the mouse (as shown below)
tried using a selection set and then highlight, but turned out that highlight is not a selection, it just highlights it in the view.
Thank you.
Solved by Alfred.NESWADBA. Go to Solution.
is >>>acDocEd.SetImpliedSelection<<< what you are looking for?
- alfred -
Hello Alfred,
No this is not what i want.
Let's say i have defined my filters and selected some entities using the editor.select(filter) function.
Then i get this selection set, and show it to the user on the screen.
Not only that, the user should be able to delete, copy, cut, change the layer, of those selected entities... (same as you would select those entities by using the AutoCAD interface).
In other words,
Suppose i have a selection set in my code, how can i select those objects in this selection set in the AutoCAD view?
have you tried it?
If you create a selectionset by filter and forward it to the ImpliedSelection then these objects get gripped, the property window shows the properties and you can change the properties you were looking for ...
- alfred -
I must have misinterpreted the post then.
I will try it and let you know.
Thanks.
Finally, thanks a million Alfred.
I also tried passing an array of object IDs 😄
Dim ed As Editor = doc.Editor
Dim objectIDs(1) As ObjectId
objectIDs(0) = curve1.ObjectId
objectIDs(1) = curve2.ObjectId
ed.SetImpliedSelection(objectIDs)
