AutoCAD Forum
Searching layer manager with Keyword
11 REPLIES 11
Message 1 of 12
9371 Views, 11 Replies
The way the layer manager search function is set up allows you to only search for a layer with an exact replication of the name of the layer. With tons of unit plan xrefs, our layer manager looks something like this:
X_13135_A5_1_FURN
X_13135_A5_1_CAB
X_13135_A5_1_RAIL
and so on... each unit xref has its own designation. So we would like to be able to search all xrefs for their furniture layers. So I could type in furn and it would show me all furn layers in each designated unit xref. Instead I have to type in x_13135_A5_1_FURN for that particular unit. For another unit I have to type in X_13135_A1_1_FURN or whatever the unit name is. PLEASE fix this it would save so much time. The screenshot attached below is an example of what our layer manager looks like.
X_13135_A5_1_FURN
X_13135_A5_1_CAB
X_13135_A5_1_RAIL
11 REPLIES 11
Message 2 of 12
dmfrazier
dmfrazier
Have you tried wildcard characters (*, ?)?  For example, *FURN*.
Works for me with ClassicLayer and LayerPalette.
Message 3 of 12
Jay_B
Jay_B
How about Layer Filters ?
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
C3D 2018.1
C3D 2016 SP4
Message 4 of 12
in reply to: dmfrazier
Yes I learned that using two asterisks does the trick. Thanks a lot.
Message 5 of 12
dmfrazier
dmfrazier
HTH Smiley Wink
HTH Smiley Wink
Message 6 of 12
conorbFR5HG
conorbFR5HG
Observer
Observer
This worked quite the trick. Thanks alot
Message 7 of 12
Shay.Gaghe
in reply to: conorbFR5HG
Shay.Gaghe
so why dont accept it as a solution?
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
Message 8 of 12
conorbFR5HG
in reply to: Shay.Gaghe
conorbFR5HG
Observer
Observer
Not sure how to Shay, im afraid. Please advise
Message 9 of 12
Additional wildcards from HELP:
# (pound)
Matches any numeric digit
@ (at)
Matches any alphabetic character
. (period)
Matches any non-alphanumeric character
* (asterisk)
Matches any string and can be used anywhere in the search string
? (question mark)
Matches any single character; for example, ?BC matches ABC, 3BC, and so on
~ (tilde)
Matches anything but the pattern; for example; ~*AB*matches all strings that don't contain AB
Matches any one of the characters enclosed; for example, [AB]C matches AC and BC
Matches any character not enclosed; for example, [~AB]C matches XC but not AC
Specifies a range for a single character; for example, [A-G]C matches AC, BC, and so on to GC, but not HC
` (reverse quote)
Reads the next character literally; for example, `~AB matches ~AB
# (pound)
@ (at)
. (period)
* (asterisk)
? (question mark)
~ (tilde)
` (reverse quote)
Message 10 of 12
Kent1Cooper
Kent1Cooper
[Because it's a three-year-old question, posted by someone else, who already accepted  what they were replying to as the solution, anyway.  Only the original poster and certainly others with special privileges can mark something as an accepted solution.  But anyone can give Kudos, if they like something enough.]
Kent Cooper, AIA
Kent Cooper, AIA
Message 11 of 12
zshakir
zshakir
That is very helpful
Message 12 of 12
timbrax
timbrax
2014 comment = life saver,
AutoCAD Inside the Factory
