AutoCAD Forum
Searchable Draawings
1 REPLY 1
228 Views, 1 Reply
The problem with the searchable text can be found on the attachment. The text that can be searchable looks normal (left). The text that is not searchable looks bold (right). It doesn’t matter if we change the font, the text always looks different. As seen in the screenshot, there are no discernible differences in attributes. The only method I’ve found to solve this issue is to use the FLATTEN command.
Tags (1)
1 REPLY 1
Bernd.Gerstenberger
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
Hi Rodrigula,
unfortunately there is nothing attached. Can you attach the drawing?
Thank you
Bernd
Bernd G.
Senior Product Support Specialist
Hi Rodrigula,
Thank you
Bernd
Bernd G.
AutoCAD Inside the Factory
