Search command
Search command
stavjan19989
Search command
stavjan19989
Hey,
I am looking for a command that by clicking on one block it will freeze the entire program except for all the times this block appears, to see it prominently in relation to the program to see its distribution and the way it is divided
I hope I explained well
and Google translated well hahaha
pic 1 - the plan
pic 2 - The result, the goal
AVCPlugins
Use _selectsimilar command. And may by add _isolate too
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
baksconstructor
SELECTSIMILAR
ISOLATE
Kent1Cooper
[The command name is ISOLATEOBJECTS.]  But that will show the SELECTSIMILAR result only, and everything else will be invisible.  That's not what they want -- the context, but faded, is part of the idea.
@stavjan19989 , are these always on a common Layer, and is there nothing else on that Layer that you want featured?  It wouldn't be hard to write a routine that would use the Locked-layer Fading option, and temporarily lock all Layers except that of a selected object.  But it would be by entire Layers.  Would that do what you want?
Kent Cooper, AIA
AVCPlugins
Nobody seemed to demand "faded". It is enough to select all the blocks of the same name and they will be perfectly visible against the background of the rest of the drawing due to the usual illumination of the selected objects.
Plugins for AutoCAD
A>V>C>
