Floor Tiles Not Showing When Printed
sherrylmarian
sherrylmarian
Community Visitor
Community Visitor
Hi everyone,
I’m an interior designer and currently facing a frustrating issue with my project files. I’ve noticed that parts of my flooring design are wiped out when printed, specifically in areas where furniture blocks the view. However, everything looks perfectly fine in the PDF view.
Here are some details:
  • The floor tiles are visible in the PDF file but disappear in the printed version.
  • This issue seems to occur in areas under or around the furniture.
  • I’ve checked the layers, and everything seems to be set up correctly.
  • My design software and printer drivers are up to date.
  • I’ve tried printing on different printers, but the problem persists.
Has anyone else encountered this issue? Any advice on how to resolve it would be greatly appreciated!
Thanks in advance for your help!
Valentin_CAD
@sherrylmarian ,
@sherrylmarian wrote:
... However, everything looks perfectly fine in the PDF view.
... Any advice on how to resolve it would be greatly appreciated!
Consider using another PDF application. (Post PDF for others to test)
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
DumR0
Hi
share a DWG to see the block
imankassab2015
Please upload one file that contains the prb to check it out
