SDI usage
SDI usage
robert.danskin
SDI usage
robert.danskin
SDI doesn't seem to be working, when i change it to 1 or 0, it doesn't seem to make a difference. i want to be able to open multiple drawings in the same AutoCAD session, I was just upgraded to version 2024, it used to  work in 2022
Patchy
Test it by shut down the PC and restart.
robert.danskin
A total shutdown and restart did not help, any other ideas?
thanks
pendean
Community Legend
Community Legend
Have you installed 2024.1.5 Update yet? ABOUT command in your AutoCAD will confirm what you have installed. If not, get it from your Autodesk Account Page here https://manage.autodesk.com/cep/#products-services/updates
Restart your PC afterwards.
Are you using OPEN command from inside AutoCAD to access all of those DWG files? You'll need to contact Autodesk Support through your accounts page.
Or are you double-clicking in File Manager to do this? If this latter, you need to fix these
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Double-clicking-a-...
paullimapa
So are you saying that after setting SDI to 0 while still in AutoCAD with a current drawing opened you enter the Open command and select another drawing AutoCAD will automatically close out of the current drawing before opening the new one you just selected?
Paul Li
IT Specialist
@The Office
cadffm
I think you talking about the case you dblclick a .dwg/.dxf file in Win Explorer.
If so, and if you can open multiple drawings by using OPEN command in AutoCAD,
it isn't a SDI thing.
The problem is: Your .dwg/.dxf/.dwr extensions are not linked to the aclaunch.exe
If we right, sesrch for ACLAUNCHER and link your Acad files to open with the aclauncher.exe
Sebastian
