as you can see from the attached dwg file I have a number of surfaces and they should be creating and enclosed area which I'd like to then convert into a solid by using surfsculpt...
Somehow it does not work.
Any help?
Thanks in advance and have a great day 🙂
Any help?
Solved by imadHabash. Go to Solution.
The volume enclosed by the surfaces must not have any gaps, and the surfaces must have G0 continuity, which means that they have continuous intersections. from Properties i check and see that you have a non closed surface . I suggest to follow this link that may help . >> Click <<
Imad Habash
Imad Habash
I will look into it !
