scriptpro for autocad 2025
krishnandynBQY9Z
Message 1 of 10
krishnandynBQY9Z
Dear All,
Can not able download script pro for autocad 2025 from this link.
Please help
Krishna
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/7xKPXzhEGzvnF4qzy2Ddi9.html
Replies (9)
Message 2 of 10
cadffm
it's on you (the link works)
Try another browser, try another firewall/antivirus
Watch the monitor carefully while clicking so that you notice every little message/change.
We cannot help directly with the information provided, we can only say that the link is OK.
Sebastian
Message 3 of 10
paullimapa
Are you able to download using this link?
Paul Li
IT Specialist
@The Office
Message 4 of 10
krishnandynBQY9Z
Dear Sir,
I have installed through local d:Drive. But it doesnot replace my title block as per the script.
it open all the drawings and close each. But does not replace. I have the same block(a1_border) in my all cad files
-INSERT
A1_BORDER=
(COMMAND \E "RESUME")
QSAVE
Krishna
Message 5 of 10
cadffm
your data is correct, all works well.
Does your Script working well manually/ open your DWG, run SCRIPT - select your script. Does it works? It should.
After your ScriptPro run, a message appears (Logfile), open/share your logfile!
(please, test it with 1-3 files only, nobody needs 1000 rows of log file)
Sebastian
Message 6 of 10
krishnandynBQY9Z
I tried autoscript also in the same files, insert title block fails. I don't know why. When doing manually it works.
Please find attached.
Krishna
Message 7 of 10
cadffm
Sorry, i support scriptpro, not non autodesk autoscript.
Please use scripro and use MY script,
Share log file then.
Sebastian
Message 8 of 10
paullimapa
Actually log clearly shows each operation completely successfully.
Perhaps you can try changing the script as a test by completing the Insert command instead of cancelling it.
Then ERASE Last object and see if that works.
Paul Li
IT Specialist
@The Office
Message 9 of 10
cadffm
..but it should work with this script too.
and by manually start works.. curios
All Autocad updates installed?
@krishnandynBQY9Z
Pls try it again in another folder!
With  dwg files in D:/test/
Sebastian
Message 10 of 10
Benjamin_AldridgeLTXAQ
Observer
Observer
If you already have a version of your titleblock defined in the drawing, inserting an updated version will not do anything. When I do this manually I have to delete the block and purge it. Maybe, instead of INSERT try REPLACE.
