Scan timber samples to create Autocad drawing
rmeyers
Observer Observer
rmeyers
Observer
Observer
We are a company that makes timber moulding and often have people bring samples from old house they want to match. Currently we tediously measure and guess and repeat until we get it right. They can take hours and hours. We only need the end profile of a moulding, is there for us to cut a slither off the end and scan it into Autocad to create a drawing? Even if we have to trace the drawing once it is in there? Thank you
jotaferrer
Hello, you kinda figured it out, in my opinion. If I had to it, I would:
- Cut a slither off the end;
- Scan it;
- Import it to AutoCAD;
- Scale that image properly;
- And then redraw it.
It's totally doable, sir! If you need further help, I can give a hand
rmeyers
Observer
Observer
Can you use a normal scanner or does it have to be a special type?
rmeyers
Observer
Observer
Thank you for your help. I am practicing with a drawing and when imported the dimensions are only slightly out but when I scale the drawing using two reference points to get the dimensions I need, the dimensions in the other direction are not correct. If I fix that dimension it changes the one that was correct and is now not correct if that makes sense. Are you able to assist?
leeminardi
Your scanner has some nonlineariries.  Try the following to calibrate the distortion.
  1. Scan a piece of graph paper that has a uniform grid of known grid size.
  2. Insert the image into an AutoCAD drawing and scale it so that the horizontal dimension is true.  When using the dist command for measurements use points as far apart as possible for the best precision.
  3. Measure a vertical distance between two points that are the same number of grid untis apart as the two points used for the horizontal distance.
  4. The ratio of the horizontal to vertical distance is the aspect ratio of distortion for the scanner.
  5. When you trace the outline of the molding in AutoCAD use only lines or polylines without arcs. If the molding has arc segements then create an arc and then convert it to lines with sufficient precision.
  6. Create a block from the tracing and then insert the block but use the aspect ratio for setting the scale in y different from the scale in x.
  7. Print the results and compare it to the physical molding.
The distortion your scanner has is probably not uniform throughout the entire scanning area. More sophisticated techniques would allow you to use multiple points in a scanned image to compensate for the scanning erros.  Google maps uses such techniques to patch together multiple scanned photos to make a composite image.
lee.minardi
jotaferrer
I'm here to help! It can be done in a normal scanner, but it should be calibrated. You can do as @leeminardi posted. If you need further help, please post here!
dany_rochefort
Use the photocopy machine to scan...
Cut your slither
Put your slither photocopy machine
Put 1 ruler on photocopy right next to your slither
Scan to PDF, highest resolution possible
Import into cad and ''scale reference'' using the biggest measure on your ruler available, either 12'' or 300mm
Put pdf on defpoint layer, lock it and trace over it using another layer
Draw a reference line next to it, 250mm for example and print your drawing to scale
Take your piece of paper, measure your reference line to make sure it really measures 250mm ''on paper'' to confirm your drawing is really ''to scale''
Once confirmed, cut it out using scissors and compare that to your slither sample
Make adjustments to cad drawing if required, 2 or 3 tries should get you there
For this to work, you need to be able to print to scale everytime.
