Scaling
Scaling
Message 1 of 24
Scaling
I dont know what to do? I want to make design center sheet. but even with symbol 1:1 scale and 1;1 scale the blocks are tiny? 1:1 sheet....ugh.
This is past conversation on You Tube.
Bummer, Ok, Im working on making a sheet to put into design center/blocks.I have several made from the old sheets. Is there a way I can drop in template and they change to correct scale. I read on forum about using user references, options. But I'm using 2017 so I cant find those options. It sound like that is what I can do.... Thanks 🙂
Luana Sloan
I have starting working at new company and all sheets are different in scale the drawing. I have set up my drawing template 1:1 I am to set up standards so all sheets the same size. I want to change all sheets, made previously into correct scale. to much to each object at a time. Is there a way to copy the drawing/model space into my template and correct the scale? Or is there a way to change the scale on whole drawing to 1:1?
Hector Barbossa
to bad... too much difference in version
Replies (23)
Message 2 of 24
GrantsPirate
Post your drawing here, it is the easiest way to trouble shoot something like this.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 3 of 24
You will see some symbols that I had taken from other drawings and from tool palette that are huge, also now that I messed with some settings at bottom of tool bar right corner my model space in paper space is not working.
Message 4 of 24
GrantsPirate
I see one solenoid symbol that is larger than the others, you would have to go into the block editor and scale everything down so rather than 12 units across it would be 1 unit across, as an example.  Otherwise I can go to Design Center and drag and drop the symbols into a 1:1 viewport and they look like the correct size.
What does "paper space not working" mean exactly?  What are you trying to do and what would you normally expect to happen?
GrantsPirate
EXPERT ELITE MEMBER
Message 5 of 24
john.vellek
Hi @Anonymous,
Has @GrantsPirate answers helped you with your issue or do you need more help?
John Vellek
Message 6 of 24
Sorry didn't get back to you. Was only working half day from home. I havent tried the scaling suggestion yet. But as far as the paper space.
When I'm in paper space and then change to model space I cant zoom in or out to fit the page. I did mess with the choices at the bottom right corner of the tool bar maybe I changed something I shouldnt have. Need help asap.
Luana
Message 7 of 24
drawing attached
Message 8 of 24
Patchy
How about unlock the viewport so it can be zoomed?
Message 9 of 24
ok that worked, I went into my dwt template, to check if there was something wrong in it? so I copy a drawing into model space and the drawing popped on paper space before I made veiwport that wont zoom in or out. So I cant fix as we did the previous situation.
Message 10 of 24
attached
Message 11 of 24
Patchy
If it automatically make a viewport when a new layout is created, in OPTIONS you can turn it OFF.
Message 12 of 24
not working, there is not a veiwport in the aps.dwt
Message 13 of 24
it wont even let me create veiwport
Message 14 of 24
Patchy
Turn all layers ON and THAW it's in there.
Message 15 of 24
no change
Message 16 of 24
done that....
I'm going to go back to previous dwt template. But dont remember how to set up sheet scale 1:1 I know it was at bottom. but cant find it.
Message 17 of 24
I found it. Sorry to be so troublesome
Thanks all for you help.
Im not an Auto Cad person.
Message 18 of 24
Patchy
Can you try this?
Message 19 of 24
Patchy
You won't see it until you click inside the VP and activate it or click on the VP itself.
Message 20 of 24
I have an existing drawing how do you add another viewport?
