What dimensions are they expecting? In your ACAD drawing as well as your screenshot the CMU wall is 21.25'x24' and the scale bar in model space matches the scale in the viewport.
Nancy
I can't check what units you are using because it's a newer version than I have and I don't have civil on this machine. I assume meters. You have objects 175,000,000 meters away from the origin. That can cause errors in the drawing. Move things closer to the origin and see if that fixes your issue. I understand that sometimes things need to be far from the origin to be in the correct map location but that many meters is over a 100,000 miles. Nothing needs to be that far for a map unless you are drawing our solar system. What happens is it creates rounding errors and those start compounding over and over when it's that far away eventually creating wrong information or other corruption.
I'm not sure what your dimensions are supposed to be so I can't really check to see what is wrong. If the other company says they are not correct then what is correct? It's helpful if you put a note or something on the drawing to let us know. Something like a big arrow pointing to something with the note that says,"This says 15m but it should really be 24m"
Nick DiPietro
Cad Manager/Monkey
