Scaling down the Titleblock block when I scale down my page
wyja8991
Observer Observer
wyja8991
Observer
Observer
I'm currently using a sheet set given by AutoCAD to design a title block. How do I scale down my title block along with the paper when I go into page setup and change the paper size from 24 x 36 to 17 x 11? Do I have to do the math and use the scale command? If you have any insight, please let me know.
Thank you
VincentSheehan
paullimapa
Really depends on your requirement. But either way I would create separate Page Setups for full size 24x36 sheet vs 11x17 sheets.
Since 11x17 is not half size to 24x36 you have the following options with the Page Setups:
1. Plot to Fit which will automatically reduce the x & y scales differently but will fit the drawing to the paper size desired. I always prefer not to use FIT to scale the drawing down because things get stretched in different directions then you cannot get an accurate scale output.
2. Plot to a factor that makes sense and will allow the 24x36 sheet to all show up on the 11x17 sheet. A custom plot scale would then be something like 1 units = 2.25
24 / 2.25 = 10.66 & 36 / 2.25 = 16 or 10.66x16 sheet
So the resulting sheet will end up with a bit of a wider border with the length compared to the width. Then I would always include a graphic scale so one can use it as a reference tool to scale the objects on the sheet.
3. Create a completely different sheet layout with a 11x17 title block which means you'll have to replicate any changes made on the 24x36 sheet onto the duplicate 11x17 layout.
Paul Li
IT Specialist
@The Office
tboehler
To avoid any scaling issues with 11 x 17 prints or PDF's.  We only use 22 x 34 paper sizes on drawing sets.  That allows for a perfect 1/2 size - 11 x 17 (printed at 1=2).    Sometimes an agency will require 24 x 36 - not very often.
In the rare occasion that we need to plot 24 x 36 paper sizes to 11 x 17 we did one to "fit" then rounded up to the nearest tenth for the scale.  Example: 1=2.2 when plotting.  We may add a note about Not To Scale on the 11 x 17 output of 24 x 36 layouts.
Cheers.
TomBeauford
While code for different government agencies often require 24×36 many engineers and surveyors simply draw 22×34 and plot them on 24×36 paper as while minimum borders are required I've never seen a maximum border requirement!
64bit AutoCAD Map & Civil 3D 2023
Architecture Engineering & Construction Collection
2023
Windows 10 Dell i7-12850HX 2.1 Ghz 12GB NVIDIA RTX A3000 12GB Graphics Adapter
RSomppi
For different size sheets, you will need additional title blocs adjusted to the correct size. Scaling a title block does not give the desired result. Not everything should be scaled. Things like text should remain the same size.
