scale
scale
tu4050955
Message 1 of 9
scale
tu4050955
Hello
My problem is that I set up the page to scale 1:100, and when I set the viewport to 1:100, it looks so small, even though I set the units and dwgunits to be the same.
and when i fit the drawing into the viewport, it gaves me this scale
it's so important to me to print it in the right scale
Replies (8)
Message 2 of 9
paullimapa
Well that all depends on what you're drawing. If the object is like your smart phone that you're drawing and you want to show that at a scale of 1:100 on a A0 size sheet of paper you'll get a very tiny object shown in the vport.
Share your drawing so we can all see what exactly it is that's being drawn.
Paul Li
IT Specialist
@The Office
Message 3 of 9
tu4050955
i  want to print A3 SIZE SCALE 1/1OO FROM LAPTOP
My unit project is in meters
so the viewport scale is not in the scale i want when i set up the scale 1000/100. it zoom inside the drawing
this the project in autocad
Message 4 of 9
paullimapa
If you’re drawing 1 unit = 1Meter and your A3 layouts is set as mm then your zoom scale factor to get 1:100 is 0.1xp
Paul Li
IT Specialist
@The Office
Message 5 of 9
tu4050955
no i want 100 unit = 1 meter
i try 0.1 but it was so small viewport
Message 6 of 9
paullimapa
try 10 according to this video tutorial:
https://m.youtube.com/watch?v=IX36rky37Ag
start at 3minute time stamp
Paul Li
IT Specialist
@The Office
Message 7 of 9
paullimapa
The issue has to do with the way you set up the page to plot. As you stated you've drawn everything in Model Space as 1 unit = 1 Meter. But as I stated in my previous post the Layouts in Paper Space should all be setup using mm paper sizes. So your Plot scale should be left as 1:1.
First I renamed your Layout6 to A3 1-100 to represent A3 sheet size plot as 1:100.
Below is a screen capture of the PLOT window with A3 paper size Plot Scale set 1:1.
Then the Paper Space Vport uses the Zoom scale factor calculated as 1/0.100XP = 10:
I also created another layout called A0 1-40. This gives you an idea as to how a 1:40 scaled drawing fits onto an A0 size sheet. Again the PLOT window is left with the Plot Scale set as 1:1.
This time the Paper Space Vport uses the Zoom scale factor calculated as 1/0.040XP = 25:
Paul Li
IT Specialist
@The Office
Message 8 of 9
tu4050955
THANK YOU SO MUCHHH
Message 9 of 9
paullimapa
Glad to have helped…cheers!!!
Paul Li
IT Specialist
@The Office
