AutoCAD Forum
Scale problem between drawings
24 REPLIES 24
Message 1 of 25
4180 Views, 24 Replies
We work with differents architects who draw sometimes in mm, sometimes in cm, sometimes en m.
We have created 3 differents pre set A3 presentation to have our page and our footer ready for any option.
I am working on a newly received drawing and when I import my presentation my footer is completely at the wrong scale with the text at the wrong place.
I have tried INSUNITS on 0 or 5,
MSLTSCALE on 0 or 1
LTSCALE on 1
CELTSCALE on 1
each time on both drawing
In both drawings units are on decimal and cm
everytime I erase the presentation and purge before trying again but it still does the same thing.
Any other idea?
Thanks for your help,
MSLTSCALE on 0 or 1
LTSCALE on 1
CELTSCALE on 1
Any other idea?
24 REPLIES 24
Message 2 of 25
oswaldodcb
oswaldodcb
Hello @Anonymous
In which units do you have the Layout?
Please send a photo of the "Page Setup Manager" or PLOT window to see the configuration of the units of the presentation,
Like this:
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
Hello @Anonymous
Like this:
Oswaldo Caballero
LinkedIn
Message 3 of 25
user181
user181
Have you checked to see if their drawing has the same text style as yours and they have a different font assigned to it? If you insert into their drawing the text style will use their assigned font.
Message 4 of 25
TrevN
in reply to: user181
TrevN
Are you saying you have your border in model space?
If you had your border in paper space, you'd only need one A3 file.
Or am I missing something?
Message 5 of 25
in reply to: TrevN
@oswaldodcb: I change the plot scale unit depending on the unit they used to draw.
I will put 1mm = 1unit when they are in mm, 10 if they are in cm and 1000 if they are in m so I can use the scale easily when I am on paper space.
@user181: we created our own text style to avoid this kind of problem, and it shouldn't affect the bloc anyway, should-it?
@user181: my border and footer are in paper space.
Message 6 of 25
pendean
pendean
Community Legend
Community Legend
Are you using XREF command to bring in the consultants drawings into yours?
Or are you actually drafting inside their DWG files?
And do you use Annotative text/blocks/dimstyles by chance, or still doing it old-school?
Message 7 of 25
in reply to: pendean
@pendean: not using xref, staight into their drawing ans not using annotative, proper old scool 😉
Message 8 of 25
pendean
pendean
Community Legend
Community Legend
That's probably why you've hit this snag and will need to rethink how you want to do this work moving forward: spend time/effort fixing drawings from tohers, or just XREFing their files into your working-just-fine-as-you desire files to get more done in a day.
May I ask if you are getting paid to constantly change other people's files? Would the bosses (or your bank account if you're a one-man island) be more pleased if you did not spend the time and effort doing that?
Message 9 of 25
We are lighting designer and we have to implant our light into architect and interior designer drawings and then send it back to them so they can keep working on it.
So xref is not an option for us, and really often they are sending us drawing with already xref drawings so it quickly become a big mess if we xref their drawing.
And yes we are paid to do it that way 🙂
Message 10 of 25
pendean
pendean
Community Legend
Community Legend
Good to know: sadly you are going to have to fix each and every file to bring into your standards (then deal with the fall-out when they get the files)
OR
you all adopt your individual partners' standards when working in each of their files, more work for you upfront once but after that it's all gravy.
We do that latter for clients with very strict standards, when xrefing their files into ours are not an option.
Good luck.
OR
Good luck.
Message 11 of 25
We do adopt their standars has a lot of them have really strict one so we gave up trying to have our own.
Still, how do I fix that scale problem if all my settings are the same in both drawing?
Where does this problem come from?
Message 12 of 25
user181
user181
Is there any chance you could post the two drawings? It would be easier to figure out that way. If you don't want to post the arch. drawing maybe you could save a copy and erase the arch stuff in model space and just post the problem in paper space.
Message 13 of 25
Here are the 2 drawings.
Thank you for your time!
Message 14 of 25
user181
user181
The units of your bureau ACAD TYPE.dwg are set to unitless and the units in the fichier probleme.dwg are set to centimeters. If you use the command UNITS on the fichier drawing and set them to UNITLESS and erase your presentation and purge the blocks out and then do a copy and paste from your bureau drawing it should come in the correct size and appearance.
Message 15 of 25
I put both drawings on unitless, erased the presentation and purged but when I import it back through the design center I still have the same problem.
I tried with both in cm and It doesn't work either...
Message 16 of 25
user181
user181
In the A3cm tab of your bureau drawing just use the copy to clipboard (CTRL+C) and then after purging and changing units to unitless in ficher drawing do a paste (CTRL+V) and insert at 0,0 and use regenall.
Just erase the items in tab A3 cm and not the whole tab and then do the copy & paste. Don't bring in the whole layout through designcenter
Message 17 of 25
user181
user181
It may be easier in the future for you to create 3 separate drawings of your presentation tabs. One for each mm, cm & m so that you can set the units for each of them accordingly and you can use designcenter to import. Because you have 3 different units in 1 drawing and set to unitless you will continue to have issues using designcenter.
Message 18 of 25
To make your solution working for me I have to do the following:
-import my presentation because my page and printer and ctb are set in my acad type drawing, but then my footer is completely at the wrong scale
-I then erased it in the drawing I am working on and purge
-I go back to my acad type and copy only my footer using ctrl+c and the copy+v in the drawing I am working on and it is at the right scale!
It works but it doesn't make any sense to me!
Thank you anyway for this at this is the best solution so far!
Message 19 of 25
user181
user181
Like I said in my previous post you need to make 3 separate drawings for your presentation tabs because they are different units.
Message 20 of 25
GrantsPirate
GrantsPirate
I know you marked a post as a solution but I personally wouldn't go with that solution.  I would recommend one title block done in mm for your A3.  Then create custom annoscales for a mm, cm, and M drawings being brought into modelspace.  You simply name each scale for the type of units needed for MS.  So if you use 1:50 scale for plotting you would have three custom scales with names like 1:50mm, 1:50cm, 1:50M, and simply pick the correct annoscale for that situation.
This keeps one title block to edit and maintain, and only one size when plotting, and any text. dims, etc, added in PS are one size rather than multiple sizes.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
GrantsPirate
EXPERT ELITE MEMBER
AutoCAD Inside the Factory
