Scale PDF, and reference points
erasmoberrios121
erasmoberrios121
Community Visitor
Community Visitor
Hello guys, I can't emphasize how much of a beginner I am, so please bear with me. I somehow managed to learn what I wanted to do by clicking on every possible option I could, and see what happened, literally.
I learned how to import a PDF into Autocad 2017, and somehow figured out how to scale part of the PDF to show info in inches using the Scale option + the reference point option, the drawing utilities/units option, and the Measure command.
I basically want to scale that PDF, and it seems like it's "vector geometry" option worked, because I can select all points/lines (don't  know how else to call them), and I know that half of that page is scaled at 1/4''=1ft, but the other half in the same page is scaled 1/2''=1ft.
So I can scale half of the page, and measure as I please that half, but I need to figure out how to select the other half of the same page, and scale it to what it's supposed to.
Sorry if I can't explain well, but here's a pic of what I did well to half of that page:
Juergen_Becker
can you please post your PDF.
I will try to scale it. But I'm not familiar with imperial Units (Inches).
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
RobDraw
Make a copy of the PDF in AutoCAD. Scale it by 2 or 1/2, which ever is appropriate.
Rob
scot-65
PDF manipulation is marginal in a DWG file.
I have found that by inserting the PDF into a "blank"
drawing, then inserting the blank drawing as a
block into the destination drawing works the best.
From there one can manipulate both the x- and y-
scales for the desired results (for the most part).
One can also rotate the block.
As a footnote, I have not tried to work with multi-
page PDF's, but will go the route of splitting and
using the desired pages as individual blocks.
And welcome to these forums!
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
