AutoCAD Forum
Scale list reset
3 REPLIES 3
kidznok
726 Views, 3 Replies
Scale list reset
Is it command to reset scale list? Cause I would like to add button with command on my ribbon.
And 2nd question - is it possible to set default scale list?
3 REPLIES 3
cadffm
in reply to: kidznok
1. -ScaleListEdit
  Option Reset
   So it is possible to write a Macro.
  https://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-BF3A0E9D-E009-45C1-A778-C6148C5CAEC8
2. ScaleLists are saved in your file, so it is possible
   for new files:
    by set up your favorite list in your template .dwt files.
    for existing files:
    by using ScaleListEdit Option Reset
  (If you think you need to edit the predefined Master list, go to OPTIONS dialog and edit the default list)
Sebastian
kidznok
in reply to: cadffm
Thank you very much.
In my company sometimes we have info in command line that scale list is big.
Where is problem in our work especially in xrefs? Are we do sth wrong?
Pointdump
Hi @kidznok,
I think the easiest way to deal with the scale list is explained by Jeff Bartels >>>Here<<<. 1:35 to 2:54.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2024
AutoCAD Inside the Factory
