Hello all. It's been a long time since I've worked with AutoCAD, so the issue here might be obvious, but I don't know what's going on. You can see on the left LP6-14,16 in a neat row, as it's supposed to be, and then it starts moving off course with some weird spacing and obviously it's no longer horizontal. I'm saving to Bluebeam 21.1 and am using AutoCAD 25.
Solved by pendean. Go to Solution.
@mloweM8V73 wrote:...I'm saving to Bluebeam 21.1 and am using AutoCAD 25.
Nothing in AutoCAD staggers letters like that, sorry: try a different PDF driver (AutoCAD is bundled with 5 of them) than BlueBeam, see if you can recreate the issue there too.
Honestly I wish I had thought of using another PDF save method. You know sometimes you get so caught up in a problem, you forget common sense.
Marking as solved.
@mloweM8V73 wrote:Honestly I wish I had thought of using another PDF save method...Marking as solved.
Glad that helped: BLUEBEAM support is often very helpful, contact them before you totally give up on that product.
