Saving Layer Property
How can a Layer Property be saved to use on another drawing?
Bernd.Gerstenberger
Autodesk Support
Autodesk Support
Hi keenerkw579,
yes, this is possible. Type command _LAYERSTATE and a dialog pops up. Here you can save the current layer state. Afterwards you can export this layer state via a las-file to another drawing. Later you can select in this dialog a layer state and click "Restore" to get this layer state active.
Best regards
Bernd
PS: If you think, this issue is solved, please, mark it as accepted solution.
Bernd G.
Senior Product Support Specialist
That worked.  Thanks!
