Saving Drawings as PDF Increases File Size Dramatically
I have a user who is using the latest version of autocad.
When they save a drawing as a PDF the file size grows from at most 6 to 8 megabytes as a drawing, to 30 to 50 megabytes as a PDF.
This had not occurred before 12/29/2020, and they are doing everything the same as before.
Is this a known issue that has come up? searching on the forums has not yielded any recent results.
Thank you
I've attached an example of a PDF that ballooned.
ennujozlagam
try another PDF printer driver like BULLZIP and see if the result is the same. thanks
pendean
Community Legend
Community Legend
Your posted PDF is damaged, cannot be opened here.
Why not post a screenshot of the PLOT command pop-up that created it, lets see what you see, and if possible, include the actual DWG file too.
Drawing files & plot command pop up.
pendean
Community Legend
Community Legend
If you only want to use BLUEBEAM, you will need to go over to their website for support, here is the link https://support.bluebeam.com/
In the meantime use one of the AutoCAD built-in PDF drivers (like DWG TO PDF) and see if your problem goes away.
