Saving/converting Autocad 2008 files to be used in Autocad 2020
I am currently using a dinosaur system and need to upgrade, but need to sort how to do it correctly.  I am using Autocad 2008 (mostly for 2D plans), with Microsoft Windows 7 version, on a 64 GB C: Drive that also needs upgrading.  (Graphics card is fine at the moment) As you all probably know Autocad 2008 is not compatible with Windows 10, and upgrading my C: Drive cannot really happen without Windows 10 (or so I’m told).  This leaves me with the problem of upgrading computer but potentially unable to access all Autocad files. So I have several issues/questions:
1. Can I save or export 2008 .dwg files in a ‘special’ way so that it is easier to then import/open in Cad 2020. This is my goal, however if there are stepping stones to achieve this please let me know!  Is this even possible?
2. My current 64GB C drive won’t allow me to download any huge new programs to do this so I am hoping there is something with low requirements to help make this happen- prefer to use something in Autocad program.
3. If issue above is solvable, is there a ‘special’ way to then import into Autocad 2020, after C: is upgraded to (256 or 512) and Windows 10 is installed?
Thank you in advance for any answers!
Kent1Cooper
There's no need to convert drawings.  You can always open older-version drawings in newer-version AutoCAD.  They will be converted to the newer format when you Save them.
Kent Cooper, AIA
braudpat
Hello
+1 with Kent !
I have loaded very OLD drawings (R2.X) with my 2021...
The Health, Bye, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
RobDraw
There is action necessary to make your files compatible with newer versions. You will get a warning saying that saving the file to the current format might make the drawing incompatible with older versions
Rob
