SAVEAS shows not DIALOG BOX
cadman1965
Message 1 of 8
cadman1965
Hi!
Can anyone help me?
I use AutoCAD Electrical 2016 and, even if FILEDIA is set to 1, I still can't get the DIALOG BOX!
Replies (7)
Message 2 of 8
imadHabash
HI,
>> I use AutoCAD Electrical 2016 and, even if FILEDIA is set to 1, I still can't get the DIALOG BOX! <<
i'm afraid that you may need to reset autocad to default settings . >> Click <<
Imad Habash
Message 3 of 8
cadman1965
Oops...
And...  what settings will I lose if i do that?
Also, will i need the "original" installation medium or folder?
Merci / thank you
Message 4 of 8
Ed__Jobe
I would try restarting AutoCAD and or the pc first.
Ed
How to post your code.
Message 5 of 8
cadman1965
@Ed__Jobe
Well...  I did that a few times since I have this problem... and when i say a few times I mean a lot !  🙂
Thanks anyways!
Message 6 of 8
dbroad
Is SAS a custom command?  If so, that might be your problem.  Try .SAVEAS  Note the period before the command. If that doesn't work the restart, reboot, reset approach might be needed.  If you are using a foreign language version "merci", then add an underscore before each command to test the built-in features, such as _.SAVEAS.  This should be automatically working by using the saveas icon in your CUI.
Architect, Registered NC, VA, SC, & GA.
Message 7 of 8
rkmcswain
Merci / thank you
I do not believe you need to do this, but if you choose to, you will be given the opportunity to save your current settings, and then it will wipe your AutoCAD profile - so that when you restart AutoCAD, it will be like the first time you launched it, under your login.
No, you do not need the install media. It's not modifying anything to do with the software, just your user profile.
The ability to go back and restore the settings saved (mentioned above) is questionable BTW. It may work to some degree.
R.K. McSwain     | CADpanacea | on twitter
Message 8 of 8
cadman1965
In fact, I have those in my "default" LISP file
(DEFUN c:sas nil (command "saveas"))
(DEFUN c:ss nil (command ".saveas"))
Also,
I think my problems came for the PGP file...  i think i wasn't modifing the good one...
Thanks to all of you!  🙂
PS:  I'm going to post a more difficult one this afternoon!
