Hi, when I try to SAVEAS or attach a file (eg POINTCLOUDATTACH) I have to type the path in manually in the command line. It used to open up a window(?) on screen from which I could navigate to the correct folder. How do I get this back?
Solved by Alfred.NESWADBA. Go to Solution.
change the system variable FILEDIA to 1 to get the file dialogs back 😉
- alfred -
