@Anonymous wrote:
Yes, the pop-up is missing.
The comamndline doesn´t show anything. It doesn´t appear the classical window to save the job.
You may try the following
(setvar "filedia" 1)
Note: I don't think this is the cause as AutoCAD is just installed and the value of filedia should be 1 by default. However, it is worth to try.
HTH
from post 11:
from previous post:
>> The problem was FILEDIA. It was in 0
SCNR: then your command-line asked for a filename after you started command _SAVEAS!
AutoCAD is communicating with the user, to see the command-line is most important to identify the current state of AutoCAD. If you can't see this (e.g. because of disabled command-line) you might lose important informations about your work.
- alfred -
>> Is it necessary to make some other correction?
Not if all is working as you expect it. 😉
I just wanted to mention the importance of the command-line for future readers ... also as it is necessary to get as much info's as possible (and correct info's) to be able to support you.
- alfred -
