SAVE AS
SAVE AS
Message 1 of 10
SAVE AS
I can´t SAVE AS my designs. What can I do?
Replies (9)
Message 2 of 10
pendean
Community Legend
Community Legend
What error message are you getting?
What exact software and year version are you using?
Message 3 of 10
Tody I made the downloading and installation of AutoCAD 2016. The problem is: I can´t SAVE AS my designs. I clik the save as icon and I haven´t answer.
Message 4 of 10
pendean
Community Legend
Community Legend
Are you just missing the pop-up?
What does the comamndline show when you do SAVEAS?
Message 5 of 10
Yes, the pop-up is missing.
The comamndline doesn´t show anything. It doesn´t appear the classical window to save the job.
Message 6 of 10
BeKirra
You may try the following
  • Copy this to command line and click enter key. Then try saveas again.
(setvar "filedia" 1)
Note: I don't think this is the cause as AutoCAD is just installed and the value of filedia should be 1 by default. However, it is worth to try.
  • You may also press F2 key to turn on command/text window.
  • Do you use multiple screens? If this is the case, check any message on other screen.
HTH
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Message 7 of 10
Everything is fixed. The problem was FILEDIA. It was in 0.
Thank you very much.
Rosangela Vieira Santos
Message 8 of 10
Alfred.NESWADBA
from post 11:
from previous post:
SCNR: then your command-line asked for a filename after you started command _SAVEAS!
AutoCAD is communicating with the user, to see the command-line is most important to identify the current state of AutoCAD. If you can't see this (e.g. because of disabled command-line) you might lose important informations about your work.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Message 9 of 10
Alfred, good day True, the command line was off. I activated it by clicking on VIEW - PALETTES. Is it necessary to make some other correction? Thank you very much for your invaluable help.
Message 10 of 10
Alfred.NESWADBA
Not if all is working as you expect it. 😉
I just wanted to mention the importance of the command-line for future readers ... also as it is necessary to get as much info's as possible (and correct info's) to be able to support you.
- alfred -
Alfred NESWADBA
