SAVE AS
SAVE AS
Message 1 of 8
SAVE AS
DEAR SIR/MADAM
I want to ask you something about save as. General ,If we drawing a draw and we want to happen automatically save without to press the button
ice_screenshot_20160509-124348.png what settings we should make ?
In addition is there setting in order to save the drawing every 30 second or 40 second (with other words is there automatically setting  the less than a minute?
Thank you
Replies (7)
Message 2 of 8
JDMather
@Anonymous wrote:
.... is there setting in order to save the drawing every 30 second or 40 second
Do you really work that fast?
I am going to recommend (based on more than 25 yrs of experience) that you take over control of saving.
In my experience, those who expect the computer to save for them - end up losing more work than any other users.
Message 3 of 8
rkmcswain
There is no automatic save function, at least in the way you are wishing (The "Autosave" function that AutoCAD does have -- makes a *copy* of the drawing, and it gets *deleted* when you exit AutoCAD)
I suppose you could write a custom routine to do what you want, but why?
Just press Ctrl+S when you want to save - you can do it every 5 seconds if you wish.
Message 4 of 8
TheCADnoob
You could probably achieve this with some scripting.
(http://forums.augi.com/archive/index.php/t-27428.html) Saves every 10 commands
(https://www.theswamp.org/index.php?topic=4735.0) saves at a time interval. you can manual set the time interval.
I would listen to the warnings of individuals who indicate that this may not be a good idea and consider what they are telling you. If you are working in a system that makes this necessary it might be work looking into addressing the problem another way.
CADnoob
Message 5 of 8
dbroad
savetime
autosave
Don't set savetime to less than 5 minutes.  The drawing will not actually be saved on a permanent basis.  It just makes a temporary copy in case your computer loses power or a catastrophic error happens. This copy can be found in your %temp% folder by default.
It is possible to set up a timed save reactor but I strongly discourage that and will not demonstrate.  As @JDMather says, you should take control over save points.  Time saves can actually destroy your drawing if you made a mistake just before a save.
Architect, Registered NC, VA, SC, & GA.
Message 6 of 8
i want to ask you something ,if i choose  ice_screenshot_20160515-134932.png to save my drawings ,because it is easy maner for me will be mistake or my drawings can not be saving?
Message 7 of 8
Kent1Cooper
@Anonymous wrote:
....if i choose  ice_screenshot_20160515-134932.png to save my drawings ,because it is easy maner for me will be mistake or my drawings can not be saving?
Read the beginning of Post 3 again.
Kent Cooper, AIA
Message 8 of 8
pendean
Community Legend
Community Legend
