.sat file error reading
Message 1 of 13
Goodmoring,
I am trying to import in Autocad 2016 a .sat file that has a v23 version; I know that Autocad reads at least v7; can you suggest me some ways to convert this file in the correct version? thanks a lot
Replies (12)
Message 2 of 13
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
Can you attach the file so I can take a look and make recommendations?
John Vellek
Message 3 of 13
Yes, i will attach the file .sat, thank you!
Best Regards
Pierini Tommaso
Message 4 of 13
john.vellek
Hi Pierini,
You might need to put it in a ZIP file in order to attach it to a post.
John Vellek
Message 5 of 13
Here is the file
Message 6 of 13
john.vellek
Hi @Anonymous,
I tried opening this file in several different applications but it failed in all of them. What is the source of the file?
John Vellek
Message 7 of 13
I have created the file with Abaqus CAE, then I have exported the model in a .sat file. I can export in different format: .igs, .stp, .vda.
I need to modified the model in a particular way that results impossibile in Abaqus, for this reason i need to export the model and open it with Autocad.
I can try to attach all the different extensions.
Message 8 of 13
john.vellek
Hi @Anonymous
I finally found a conversion program that allowed me to get it into Inventor and then to a dwg format.
I have attached here for you.
John Vellek
Message 9 of 13
Thank you a lot for the support. Now i can per the file in Autocad but the model is made up of triangles and it is quite impossibile to work on it, can you suggest me a way to transform all the features in surfaces? Thanks
Message 10 of 13
john.vellek
Hi @Anonymous,
Try exploding the object and then run convtosurface. I think that might work for you.
John Vellek
Message 11 of 13
Thanks, the triangles now are surfaces but I have still one problem: I would like to work with a unique surface, how can I merge the singles parts into one bigger surface? Thanks
Message 12 of 13
john.vellek
Hi @Anonymous,
I am sorry for the delay.
I have been working on the converted file and I have not found a nice way to clean up the triangulated surfaces. They are likely the result of the conversion process.
I started to emulate some of the parts by drawing them directly in AutoCAD and they look and behave much nicer. Here is a screen shot of surfaces on the left created in AutoCAD compared to the converted ones on the right.
I suspect that it will likely be faster to recreate this in AutoCAD or maybe better even to do this in Inventor or Fusion 360.
John Vellek
Message 13 of 13
Thank you so much! I really appreciated your interest. I have found the way not to redraw the model:
The problem is that on the MAC version of Autocad is impossible to import a STEP file; I have used Autocad on Windows and i have finally reached my goal! thank you so much again!
