Same text-style(font) in different files plots different
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a .DWT template as a drawing-header with a block with attributes.
When plottning to PDF:
When the DWT is plotted, the text looks different than when I am using the template in a layout in a DWG file. I have not changed the block in the template, and in block editor it shows the text has the same text-style and font as in the original dwt.
The text is looking very thin in the wrong-looking plot, it should look more bold(see attached images).
- The attached file "dwt plot(correct) is the "correct" look, how the text in the plot looks when I open the .DWT file itself.
- The attached file "dwt plot(wrong) is how it looks in a dwg file I made.
- I am using the same plottning style table(default Monochrome)
- The text style is Romans and font is romans.shx in both the DWT and the DWG(as attached image).
If I copy the .dwt title block into the dwg file, it shows up wrong(very thin) when plotting the dwg's layout.
If i copy the title block directly from the dwg file into the dwt file, the text in that block plots correct(bold) when plottning the dwt layout.
What could be the problem for this?
Best regards
