Rotating Annotative Text
不适用
2,595 次查看
5 条回复
1 条消息(共 6 条)
不适用
Hey, I've created an annotative text style, like you do, because I want to make sure all of my text is the same size.  However, I'd like to rotate a few notes so some are vertical, and some are at 45 degrees, while keeping some standard horizontal notes. When I go to rotate my text it does revolve around my base point but it remains printed horizontally. I've noticed others have had this problem over the years. Is there a solution for this yet other than reverting to a non-annotative text style?
0 个赞
2,596 次查看
5 条回复
回复 (5)
2 条消息(共 6 条)
user181
Select your text and on the properties palette set Match Orientation to Layout to No. This is also a setting in your text style definition, uncheck the box in the text style that says Match text orientation to layout.
0 个赞
3 条消息(共 6 条)
vinodkl
Make sure you have the option "Match text orientation to layout" is unchecked in text style and apply the changes. You could also select the text and change "Match text orientation to layout" to "NO" from properties palette.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
0 个赞
4 条消息(共 6 条)
imadHabash
as i understand ... that your requirement is to rotate the Text in a way appear horizontally in a certain scale BUT in another scale the same text rotate 45 degree . if that your need you can do it after set current your scale to the text that you want to rotate then you can move it and rotate it as you wish .
Annotative text ... one word with multi orientationAnnotative text ... one word with multi orientation
Imad Habash
0 个赞
5 条消息(共 6 条)
duke6258
Observer
Observer
@imadHabash, that is what he is asking, but rotating the text in any scale rotates the text in all scales. Is there a way to rotate an annotative text in only one scale and not the other as @Anonymous is asking?
0 个赞
6 条消息(共 6 条)
pendean
Community Legend
Community Legend
No, assuming you tried grip-editting that one text instance at that one annotative scale and it failed to meet your needs.
