Rotated plot
Rotated plot
cs2kplus
Message 1 of 25
Rotated plot
cs2kplus
Why is my plot rotating 90 degrees clockwise?
Wayne
Replies (24)
Message 21 of 25
cs2kplus
These all look good. I wonder if my acad to pdf file is screwed up?
Thank You for taking the time to do this!
Message 22 of 25
paullimapa
maybe you don't have the latest updates installed?
what's your autocad version?
enter ABOUT command, do a screenshot and share that here
Paul Li
IT Specialist
@The Office
Message 23 of 25
cs2kplus
Thank you Paul! I saw something online that said in settings (which is actually preferences) that you can cjange Acrobats rotation to off. But I don't see it.
Message 24 of 25
cs2kplus
Hi Kent,
I don't have those bleed paper sizes for 11 x 17. I understand what your saying about flipping the numbers.
When I batch plot there is an option to use page layouts as saved. But I don't have those "bleed" options you have if I use the microsoft printer.
My batch plot comes out in the right orientation, but does not look good. Yes my preview for single plots is great. There is no preview that I see for batch plot.
WayneF
Message 25 of 25
paullimapa
There's no setting since that Adobe PDF printer device works perfectly as is with all other applications in Windows.
The issue is that the Adobe PDF built in paper sizes are designed for Portrait orientation.
So if you want a Tabloid size to give you Landscape orientation then you'll have to add this as a custom page.
So try this:
First close AutoCAD
Open your Windows Printer folder
Right mouse click on Adobe PDF printer
Select Printing Preferences
On the Adobe PDF Settings tab next to Adobe PDF Page drop down and select Tabloid
Then select Add button
Note that by default Width is smaller dimension & Height is the longer dimension which is setup for Portrait
For Paper Name enter 17 x 11
Change the Width to 17.0
Change the Height to 11.0
and click Add/Modify
Now when you drop down the Paper Size list you'll see at the top the added paper size:
Click OK to dismiss this window
Now launch AutoCAD, open your drawing & enter the PLOT command
With the Adobe PDF printer selected under Paper size drop down, scroll down this list & you should now see the 17 x 11 paper selection you added
Right away you'll see the preview change in orientation:
Complete your plot and the orientation now will be Landscape as attached pdf.
Paul Li
IT Specialist
@The Office
