Autocad LT 2015 - I want to rotate the model space object in paperspace viewport so that it view is viewed differently in paper space.
does viewcube solve your question?
- alfred -
ucsfollow = 0
put your cursor into the viewport.
e.g. rotate your UCS 45degree
command : ucs > z > 45(input angle)
command : plan
e.g. rotate your UCS follow an object angle
command : ucs > e > pick the object you want to follow
command: plan
hope this help
Leave MS objects alone and instead go to PS and rotate the viewport.
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
