ROTATE command
ROTATE command
Message 1 of 20
ROTATE command
I am looking for a very specific use of the ROTATE command. I am trying to simulate the alignemnt of a 200mm wafer using 2 pins.
The idea is we cut 2 notches (a V notch at end of the wafer and an L notch at the opposite end). The wafer pivots about the pin that locks into the V notch and rotates until it hits the L notch. This results in a coarse alignment of the wafer.
I am trying to understand how I can simulate the effects of notch imperfections. As an example, what would happen if the base of the L notch is 100 um lower than where it is supposed to be. In such a scenario, how can I use the ROTATE command (the base point would be the center of the pin that locks into the V notch) so that the base of the "new" L notch is still a tangent to the stop pin (the pin that hits against the L notch).
See the attached PNG file that explains the problem statement. I wish to achieve this w/o having to calculate the rotation angle required.
I was really hoping that I could snap to the tangent as I rotate, but that does not work.
Any advice would be much appreciated.
Thanks.
Avi
Replies (19)
Message 2 of 20
john.vellek
HI avishekaiyar,
This sounds tricky. Is it possible to attach a sample file so I can try to emulate what you are asking for?
John Vellek
Message 3 of 20
John,
Attached is a dwg file.
Thanks a lot for the help.
avi
Message 4 of 20
Thanks.
Avi
Sounds like something that Inventor would be well suited for.
Message 5 of 20
SEANT61
You could use a circle as a constructional aid, then Rotate with the Reference option to align it to the two intersection points.
May your cursor always snap to the location intended.
Message 6 of 20
Kent1Cooper
That works only if the "base" of the "L" is radial to the larger Circle.  Theirs is not.  An exaggerated example [blowup of the immediate area on the right:
Kent Cooper, AIA
Message 7 of 20
JDMather
Are you a student?
If so, then I would download Autodesk Inventor for this and learn about Contact Sets, or better yet, Dynamic Simulation.
Message 8 of 20
john.vellek
Hi Avi, I hope some of the suggestions in this thread help. I too, was going to suggest a construction circle to be used for a reference. This is what I have done for a long time but as you point out, it does have its limitations.
Is Inventor an option for you?
John Vellek
Message 9 of 20
John/All,
Thanks so much for all the suggestions. I am going to try the circle option and see what I get.
I am not a student, but if I show enough promise with Inventor I might be able to convince my company to purchase it.But I can try it out.
Thanks.
Avi
Message 10 of 20
what I did as a quick and dirty alternative is to simply rotate the wafer in discrete and tiny steps until the L-notch "looks" tangential to the pin.
Not the most elegant approach but gets me with 10s-100s nanometers of the errors I am trying to calculate, which might be ok for now.
Thank you.
Avi
Message 11 of 20
john.vellek
Hi Avi,
Along that thought, can you construct a tangential line and then measure the angle of rotation? If this works you could probably right a macro in Action Recorder to automate some of the steps for you.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 12 of 20
JDMather
Actually, I don't think you need Inventor for this - I think it can be done correctly (not just trial and error) using the Geometry Constraints on the Parameters tab.
Message 13 of 20
Joh
@john.vellek wrote:
Hi Avi,
John,
That may not work since I wouldn't know what angle to draw the tangent line at.
But let me try.
Thx.
Avi
Message 14 of 20
I didn't know about that option. Thanks for pointing that out.
Let me try that out.
Thx.
Avi
Message 15 of 20
SEANT61
"That works only if the "base" of the "L" is radial to the larger Circle."
Good point.
Message 16 of 20
john.vellek
HI @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if a post or posts fully solved your issue or answered your question.
John Vellek
Message 17 of 20
Hi Sean,
I think this approach will work really well.
Could you type out the sequence of steps? I really couldn't follow the steps as they were playing out in the video.
Really appreciate the help.
Thank you.
Avi
Message 18 of 20
Kent1Cooper
It's the approach I used to get the doesn't-work-exactly image in Post 6, so you may want to reconsider....
Kent Cooper, AIA
Message 19 of 20
aah.....I just saw that.
Message 20 of 20
Folks,
Thanks a ton for all your suggestions.
I think for the moment I am going to stick to my quick and dirty approach.
I did get a demo on SolidWorks and there is a very elegant way to do exactly what I want (collision detection between parts). I might just go down that path long term.
Avi
