AutoCAD Forum
Room Area - Hatched
6 REPLIES 6
1114 Views, 6 Replies
Room Area - Hatched
Currently working on a project where each room of a floor plan needs to be zoned by a coloured hatch which references to a colour key on the title block. My question is this... is there a quicker/ better workflow than tracing around the room outlines with the polyline command then hatching the polyline.
I have looked at the pick point & gap tolerance options but it takes a long time and often freezes.
Any advice would be appreciated
Thanks.
Room Area - Hatched
Thanks.
6 REPLIES 6
ennujozlagam
ennujozlagam
So far that's the only way to do it. If it freezes try to install latest updates from autodesk and see if helps. thanks
imadHabash
imadHabash
for me ... tracing lines is the best practical way . just turn off all unwnated layers and with proper osnap to make it easy for work and when you finish ... believe me you will get accepted and elegant work .
>> I have looked at the pick point & gap tolerance options but it takes a long time and often freezes. <<
it's Normal ... especially when you have a lot of details lines and arcs around .
Imad Habash
Imad Habash
dbroad
dbroad
If you move up to AutoCAD Architecture, spaces and walls are associative and you can control their display style based on display themes that have their own legends.
Architect, Registered NC, VA, SC, & GA.
Create the polyline for the boundary (don't forget to close it) then use the select objects method instead of pick points in the hatch command.
At the Select Objects: prompt, you could type in L as a way of selecting the polyline without having to pick it.
Kent1Cooper
Kent1Cooper
What I typically do is to make a Layer for door- and window-head edges [which I will use in reflected ceiling plans, but turn off in regular floor plans], and draw Lines only across the door and window openings, rather than Polylines all the way around the rooms.  Then with just the wall and door/window-head Layers on [plus, of course, the Hatching Layer on and current], Hatching rooms by picking points is easy and quick.
Kent Cooper, AIA
Kent Cooper, AIA
ara_neresesian
ara_neresesian
hi
just for faster action just Ctrl+c the area which you want to do hatch in to a new drawing with paste as original
coordinate  and then run hatch command .
in the new drawing its so fast because it is a light file not so heavy
and when you done you can cut hatch and paste it to your original file  with  paste as original coordinate
i am using this method when my file is to large.
hi
AutoCAD Inside the Factory
