Romans true type font
Hi
We used to make text bold and use superscripts and subscripts with romans font.  Now it is greyed out and apparently it has something to do with true type font?  How do we overcome this, as our preferred font, and the one which has been standard to our company for 20 years, is romans?
Derryck
Replies (25)
mikael.santospj
Hi, whi does this happen?? I am facing similar problem witth isometrics from Autocad plant 3D. Our client uses romas.shx, but when I try to find a word in the plotted pdf, it does not match properly. Is that possible to make Autocad see Romans like it see Arial fonts: with A "TT" indicator on the text style -> Font name??
mikael.santospj
Hi, does this only works for MTEXT?? not to block attributes???
cadffm
>>"whi does this happen??"
What?
The switch from ttf to shx? Read this thread again.. there is (or is not) a standard setting, which forces Acad to use the .shx font instead .ttf
TTFs data cannot be processed by many machines,
In addition, TTFs can lead to severe performance losses,
I think that's why it was introduced that way - and has remained that way to this day.
This default setting is not the same in all toolsets, but it is the same for AutoCAD and LT
>>" but when I try to find a word in the plotted pdf, it does not match properly."
Before you change standards, what does your EPDFSHX setting look like? AutoCAD should actually create comments with the same text values, which can then be searched and found in PDF.
(in some PDFviewers you can't see a selection over all, but you can jump from one hit to the next one)
This has been improved from version 2024.
Check your EPDFSHX setting
>>"Is that possible to make Autocad see Romans like it see Arial fonts:"
>>"with A "TT" indicator on the text style -> Font name??"
As I wrote above: Yes. And it is also explained how.
But as I also wrote above, I wouldn't prefer to do this
(just for people who have not to ask such things / Acad can't handle shx+ttf side by side well, so it is a bad idea)
>>"Hi, does this only works for MTEXT?? not to block attributes???"
To all item, also attributes
Despite all warnings. Read this thread again, make two copies of this file, one remains original and in the other you delete the line in question,
then save the file to the original location.
Restart ACAD and test.
Sebastian
mikael.santospj
OKAY, I understand...See image attached. The problem that remais when I use romans.shx end EPFSHX equals 2, for example, is the search result. I didn't seems precise..
cadffm
@cadffm  - this post has been edited due to Community Rules & Etiquette violation.
>>"I didn't seems precise.."
You are talking about the blue mask? and the inaccuracy is that the blue mask is slightly larger than the search word?
So, save a backup of the original .ini and edit like i said.
Note: After this, you can choice between both (.shx and .ttf)
Sebastian
cadffm
@ cadffm  - this post has been edited due to Community Rules & Etiquette violation.
@Discussion_Ad or whoever edited
Please excuse me, I really wasn't aware that this small talk part was against the rules 😮
@mikael.santospj
Let us know about your experience with this solution.
to whom you forward the files, the same applies to you so far, because the standard in ACAD/LT is that the program should use .shx.
One difference between .shx and .ttf is: .shx takes line width into account, .ttf doesn't!
Sebastian
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
