Romans true type font
Hi
We used to make text bold and use superscripts and subscripts with romans font.  Now it is greyed out and apparently it has something to do with true type font?  How do we overcome this, as our preferred font, and the one which has been standard to our company for 20 years, is romans?
Derryck
Replies (25)
Alfred.NESWADBA
>> with romans font. Now it is greyed out [...]
ROMANS is a SHX font on my system, not a true-type font. Do you have a ROMANS.TTF?
If you also have a SHX, why asking about "has something to do with true-type font? I don't understand the question then.
Please, as next step:
  • If it was different previously, what changed? Are you now on a newer AutoCAD version? Or any other changes?
  • Which version of AutoCAD are you working with? (Please show a screenshot from command/dialog _ABOUT)
  • Does the same happen in a new dwg-file
What is greyed out, buttons in ribbon or mtext toolbar? A screenshot from that would be great, as well as a dwg-file where you have this issue
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
imadHabash
 Romans font hasn't bold preview !! are you talking about another font ? would you show us an image about your issue please ? 🙂
Imad Habash
If you also have a SHX, why asking about "has something to do with true-type font? I don't understand the question then.  We have a romans.ttf in our windows/fonts folder.
  • If it was different previously, what changed? Are you now on a newer AutoCAD version? Or any other changes?  We upgrade our autocad every year, we are currently using autocad 2019.
  • Does the same happen in a new dwg-file Yes.
What is greyed out, buttons in ribbon or mtext toolbar? A screenshot from that would be great, as well as a dwg-file where you have this issue The ribbon.
Thanks.
Alfred.NESWADBA
Then I'm out, because I don't have a ROMANS.TTF
But maybe more important: Look to your own screenshot, it does not point to a ROMANS.TTF, it points to ROMANS.SHX:
Also your drawing ... going into dialog of command _STYLE shows that you assigned a SHX font!
>> Your screenshot
...shows that you have not installed any update yet. It should be "AutoCAD 2019.1.2"
Start with updating your software!
If you really have a ROMANS.TTF (best to be tried by starting MS-Word and try to select this font) you might go this workflow
  • Find all files named "ROMANS.SHX"
  • Rename them to "ROMANS_ORIG.SHX"
  • Then start your drawing again and see if that works, but be prepared that you might need to rename all files back to the original name.
- alfred -
Alfred NESWADBA
Alfred.NESWADBA
I have to correct myself ... in Windows I do have a ROMANS.TTF, however AutoCAD does not show me this font.
Looks like if AutoCAD finds a SHX it does not use the TTF, renaming might help .. can't await your feedback 😉
-  alfred -
Alfred NESWADBA
cadffm
No, the ttf romans is mapped like monotxt, isocp and so on.
(I prefer to NOT CHANGE this standard setup if you exchange your cad files with other people)
If you like to use these truetype fonts (which is standard mapped to a shx font in Acad), then
you have to use your own mtextmap.ini file (located in your program files folder).
Please save the original end edit a copy.
Sebastian
Alfred.NESWADBA
Much better workflow!
- alfred -
Alfred NESWADBA
Thanks.  I can't seem to edit the file though, see below screen capture it says I don't have permission.  As you can see, I assume that I have to edit the line circled to .ttf file?
Alfred.NESWADBA
if you are admin then give you the permission to edit the file, otherwise ask the admin to give you the permission(s).
- alfred -
Alfred NESWADBA
Hi.  I am administrator (see blow capture)... but it won't give me permission to edit this file?
Alfred.NESWADBA
>> I am administrator
That does not mean that your editor was started with admin permissions.
  • You can either start your editor with right-click ==> "start as administrator"
  • Or you can right-click the file ==> properties and there set the permissions to full and then edit the file
- alfred -
Alfred NESWADBA
cadffm
copy the file and rename (to mtextmap.iniorg or what you like)
paste the file in another folder
change the content
copy the file the the source folder
Sebastian
I managed to change the .ini file as shown below, but still cannot get bold in multiline text?
cadffm
1. Bold id prossible if you are using the TrueTypeFont and you are not using the ttf current.
2. You have to REMOVE the whole line from the file! (and restart AutoCAD)
3. As i wrote: I am thinking thats not a good idea because
   3a) You know nothing about these thing - Therefore, I think that you might have used a very different thing in the past!
   3b) As i wrote: It can be a problem when you exchange files (we son't know what you do with your files)
Sebastian
Thanks.  I have got a copy of the original and deleted the line, but I still cannot get bold (see below capture), although the romans has changed to romanS <=big 's'?
cadffm
I am pretty sure you are mix shx and ttf now (really bad and this is one of the points why i prefer to NOT go this way).
Please start a new file, create a new style (with RomanS ttf), start a new MText and try it again.
Thats just for testing, just to see that it can work on your system with the current ini - it should working.
Sebastian
You are right, thank you, it works when I start a new drawing and make a new style with romanS.  But, I need it to work in the drawing I am working on?
cadffm
I am Petty Sure you wasn‘t use Romans ttf and perhaps never Used the Original Romans.shx
Ask in your Company who customized the acad program or if possierlich, search a old Setup pc ehrte we can check what way you gone in the past .
perhaps you are wring with Romans and you mein other fonts
Sebastian
cadffm
OMG - This happen if you are using a iphone (fail 1) with standard setup (fail 2) and german language layout + spell checker (fail 3)
It is extremly hard to write an english text Robot Frustrated
I am petty sure you wasn‘t use Romans ttf and perhaps never used the original Romans.shx.
Ask in your company who customized the acad program
or
if possible, search for another old setup pc, where we can check what way you gone in the past .
Perhaps you are wrong with Romans and you mean other fonts (because inseide youre sample dwg there are non-standard fonts set for styles)
Sebastian
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
