i try to convert the surfaces object to a solid object using thiken, when i use thiken AutoCad says this: "1 surface cannot be thickened with specified value. Object intersects itself." I know that im introducing the wrong values, bu i need someone to help me, maybe someone can says me the right values to the surfaces.
Solved by john.vellek. Go to Solution.
Hi @Anonymous,
I used thicken on each of the pieces individually and set a thickness of .0001. I had no problem using Union after that to create a single solid.
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
