Hi.
When I select the UCS icon and right-click, I get a right-click menu, but there is no options for UCS there. I thought it should give me options regarding the UCS and the UCS icon. Using vanilla AutoCAD 2013. Any idea?
\Freddy
"Options > User Preferences > Shortcut menus in drawing area" is checked.
I get a right-click menu but it does not look like yours. My menu looks the same if I right-click in the drawing area without any objects selected. Something in the CUI?
Multifunctional grips is working the way your video shows.
\Freddy
It is the same right-click menu if I select the UCS icon or not.
We use enterprise menu (CUIx) and I can see that the shortcut menu in ACAD.cuix (that is partially loaded) has the right settings. It looks the same as your right-click menu in the video (and what I was expecting). The right-click menu seems to work on all other objects except for the UCS icon. Strange. What else to check?
Thanks. I transfered the Shortcut/UCS to my local CUIx and then it worked. I do not think this is the right way because all my other shortcuts (right-click) seems to work. I assume this is a bug. Anyway, it works now. Thanks again.
\Freddy
