My autocad make a fatal error and when I restart it, i can't move an objets with the mouse with the right click? please help me
Mon autocad a fait un erreur fatal et au redémarage je ne suis plus capable de déplacer d'objet avec le click droit de la souris qui ouvrais une petite boite de dialogue pour choisir entre déplacer, copier, copier en block ou annuler ???
Solved by oswaldodcb. Go to Solution.
Solved by rkmcswain. Go to Solution.
Hello @sebastien.groupe.cadoret
Welcome to the forum!!
If you can put an image of the error we could help you more,
This happens with a specific file or in general?
And did you start presenting it when you dropped a block or inserted something in particular?
Oswaldo Caballero
Instructor ATC
AutoCAD Certified User
Oswaldo Caballero
Project Engineer / Autodesk Certified Instructor / Autodesk AutoCAD Certified User and Professional
Maracaibo, Venezuela
LinkedIn
Da un Me Gusta si la publicación ha sido de utilidad y si ha resuelto tu duda presiona ACEPTAR SOLUCIÓN
its start when i had a fatal error, after i reboot my computer, in all my drawing, new or old if I try to select something with the mouse and right click to drag for copy or move it it dose'nt work
I solve my problem ..... PICKFIRST was set to 0 after the fatal error...i put 1 and it's ok.
But i want to know why setting change with a fatal errror ?
Sometime its the FILEDIA and now the PICKFIRST? Does it have something to do for NOT change the setting after a Fatal error ? or just stop having fatal error if its possible lol
When that happens you should check the system variables, you do it from the SYSVARMONITOR, you attach an image so you can check when a variable is unconfigured, and activate the notifications so it will not give you more headaches and warn you when they change,
I hope it is useful for you, regards
If my publication solved your concern Accept the SOLUTION
Oswaldo Caballero
ACT
Oswaldo Caballero
LinkedIn
Please check to see if you have the most current driver for your graphics card. I am hoping that might fix the crash when you start AutoCAD. Do you get an error message and then a chance to submit a report? If so, please send me the CER number.
You might also try starting AutoCAD with the No Hardware switch - steps are in this article.
Please tell me your OS, Graphics card model, and AutoCAD version
If you create a new user account on your computer that has full administrator permissions and then logon with it, does AutoCAD still misbehave?
Perhaps your user profile is damaged.
